Upgrade tms error
I´m trying to upgrade tms from version 12.6 to version 13.2.2. The tms haven´t tms agent option key and neither vcs have the provisioning option key.
When upgrading, the next error appers :
"The installer has detected that provisioning is enable on one or more vcs cluster on this server. You need to disable provisioning on all clusters before running the installer again. The installer will now abort"
Anyone know what is the problem ??
I see the xconfiguration sip route to the vcs and is correct, the result is ok. Also i see the option key in the vcs and tms and haven´t provisioning or tms agent option key. The vcs have the version x7.2.2
Best Regards
thobonho
You need to set a boolean value to false to disable replication in the database.
Look at this thread for detailed instructions:
https://supportforums.cisco.com/thread/2152730
Best Regards. Worked properly!!
