use cisco unity connection
Hamada Ahmed
I have MCS CUCM ver 8.6 and voice gateway 2911 , Can I add Cisco unity connection , to allow IVR and 4 users as call center ?
Hi Hamada,
If you are installing Unity version 8.x, you can use UCS\BE6K or any MCS server available with you.
For integrating Unity as SCCP see below
https://www.youtube.com/watch?v=2MmS1qQPtwI
For integrating Unity as SIP see below
https://www.youtube.com/watch?v=ah17T5S5C3k&t=10s
(Rate if it helps)
JB
8 Replies 8
Jitender Bhandari
Hi Hamada,
Yes you can always all Unity to your existing setup.
(Rate if it helps)
JB
so , what i need to add cisco unity ?
Use UCS server or BE6k?
and how integrate it with my MCS CUCM ?
Hi Hamada,
(Rate if it helps)
JB
last question
now available only unity 11.x and 10.x , are they compatible with CUCM 8.6 ?
also i need to deploy it with lowest price which server you recommend ?
Hi Hamada
If you have the CUCM ISO, Unity is bundled with it. But Unity 8.X is end of sale\support. I would recommend you to upgrade to latest version. For upgrade regarding help line BOM and all, contact your accounts team and they would help you.
(Rate if it helps)
JB
it will cost  , also
if i have ISR router with CME , i can make IVR and hunt group ?
You would need CUE to play any announcement, but yes you can use hunt groups in CME.
JB
There is option can use it for call recording
