User Authentication restrictions for MRA
aalejo
Level 5
Level 5
Does someone knows if is posible to restrict the users that can authenticate using MRA?
Alex
Jaime Valencia
AFAIK there is no way to do that, if a user is enabled for IM only, Phone only, or full UC, and you have MRA, he can try to login, and should be able to. CUCM will accept any proxied registrations, assuming right credentials are provided.
java
if this helps, please rate
Jaime Valencia
java
Thats what i suspected but it is not good since expressway solution currently does not protect against authentication DDOS atacks. (embedded freeware GNU fail2ban only protects againts same IP authentication failure).
Alex
There is an authentication rate limiting mechanism built into VCS 8.5.2 and above.
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/config_guide/X8-7/Mobile-Remote-Access-via-VCS-Deployment-Guide-X8-7.pdf
Page 40 goes over the feature.
Does not rate authentication failure. I opened a TAC case an a bug id was created as a result
https://tools.cisco.com/bugsearch/bug/CSCux29269
It rates applications that tries to authenticate many times but not authentication failure.
Too bad that feature does NOT protect against authentication DDOS attack.
