11-20-2007 04:53 AM - edited 03-17-2019 09:11 PM
i need to use half of the channels for the inbound calls and half of the channels for outbound calls.
What would be the Configuration?
11-20-2007 09:44 AM
Are you using CM, and if so with MGCP or H.323 ?
If H.323, place the isdn interface in trunk-group. Under said trunk group set the maximum number you want for incoming and outgoing.
interface serial x/y:15
trunkgroup mytrunk
trunk group mytrunk
max-calls voice 15 direction in
max-calls voice 15 direction out
dial-peer voice 100 pots
destination-pattern ...
trunk-group mytrunk
11-20-2007 09:25 PM
Thanks Paolo Bevilacqua! for replying but this solution is not working, I am using CCM 4.1, and MGCP on 3620.
