VCS CLI command for active use of licenses
pbzijerveld
Hi All,
Is there a CLI command that displays the current license use of the VCS? in call, peak and maximum.
Thanks!
You can do
echo "xStatus ResourceUsage" | tsh
from the root prompt, which will yield the following output:
~ # echo "xStatus ResourceUsage" | tsh
Welcome to
TANDBERG VCS Release X7
SW Release Date: 2012-
OK
*s ResourceUsage:
     Calls:
       Traversal:
         Current: 0
         Max: 1
         Total: 2
       NonTraversal:
         Current: 0
         Max: 1
         Total: 2
     Registrations:
       Current: 0
       Max: 2
       Total: 3
*s/end
OK
5 Replies 5
awinter2
Level 7
Level 7
Hi Pieter,
the 'xStatus ResourceUsage' command will give you this information (When run from an admin SSH session):
*s ResourceUsage:
     Calls:
       Traversal:
         Current: 0
         Max: 1
         Total: 2
       NonTraversal:
         Current: 0
         Max: 1
         Total: 2
     Registrations:
       Current: 0
       Max: 2
       Total: 3
*s/end
Thanks Andreas,
Is there a way to request this information from the root SSH session without using the tshell?
or is there a way to run the command like "tshell xStatus ResourceUsage" ?
You can do
Welcome to
OK
*s ResourceUsage:
     Calls:
       Traversal:
         Current: 0
         Max: 1
         Total: 2
       NonTraversal:
         Current: 0
         Max: 1
         Total: 2
     Registrations:
       Current: 0
       Max: 2
       Total: 3
*s/end
OK
To be honest, I would recomend not to use root for such cases, as you want to keep the root access quite limted.
(the root user or a script that uses it can really damage the vcs).
The admin user and ssh is one way, the other is to create a new user with read access for the api and use a web script
to get the data out. Works great for us!
Hi Martin,
It's not my favourite either, but i have some Phython skills, so i thought it was a good beginning . I am looking at the cisco support site for API documentation, but cannot seem to find it. Are there specific doc's i can use?
Thanks!
