VCS Cluster Question
Justin Ferello
Level 5
Level 5
Hey all,
We have two VCS Expressways in a cluster.  One VCS is on one Internet circuit and the other is on a separate circuit from another provider.  The Internet provider for the one VCS sucks for video, its only needed as a backup circuit.  Can I put this VCS into maintenance mode until the circuit feeding the other VCS fails?  This way, all registrations are forced to the VCS with the best Internet circuit.
If the one VCS is in maintenance mode, will it still sync within the cluster?
Thank you,
Justin Ferello
Technical Support Specialist
KBZ, a Cisco Authorized Distributor
http://www.kbz.com
e/v: justin.ferello@kbz.com
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
2 Accepted Solutions
Justin -
I went ahead an put one of our VCS peers into maintenance mode earlier today to get around an issue, and it is still enabled to this point.  Checking the clustering page on the master VCS, it shows the peer is still active.  With replication status of succeeded, even up to this very minute.  It looks like everything is fine, but like you'd it would be good to hear from someone official.  Even if we do force one peer to essentially be in a passive state until we bring it out of maintenance ourselves to become active again.  Unlike a 6 peer cluster where the last two will automatically become active when one of the primary 4 peers goes down.
Justin,
Even though you put the server in maintenance mode the cluster sysnchronization continues.
As Patrick mentioned in the previous note the page shows active. you can do another test if you want. put a server in maintenance mode and create a zone or modify a rule on master server, when the next synchronization happen it will get replicated to VCS in maintenance mode.
I think it answers your query.
Alok
8 Replies 8
Patrick Sparkman
I'd like to know the answer to this as well.  We have a different situation, but putting one of our cluster peers into maintenance mode could help alleviate an issue were having until a permanent fix can be worked out.
Justin Ferello
Level 5
Level 5
Patrick,
Thanks voting this up
This would also be a great way to do an Active/Passive cluster instead of Active/Active
Anyone from Cisco?
Where is Alok when you need him
Thank you,
Justin Ferello
http://www.kbz.com
Thank you,
Justin Ferello
Justin -
Patrick,
Thanks for the taking the plunge and testing this and reporting back with your findings.
Justin
Thank you,
Justin Ferello
Justin,
Alok
Alok Jaiswal wrote:
Justin,
Alok
The last part of your comment Alok makes perfect sense, as everything I've looked at mentions that maintenance mode only affects device registrations and call attempts, mentions nothing about synchronization between cluster peers or the like outside of the two things I just mentioned it does affect.
Patrick
Alok,
Thank you for the official "Cisco" confirmation on this.
Thank you,
Justin Ferello
http://www.kbz.com
Thank you,
Justin Ferello
Depending on how the setup looks like (like plenty of (chaning) search rules, transforms, zones, ...)
If could also be worth looking into not even let them run as a cluster but just as a lower priority.
But it all depends on the deployment.
Is can be handy to lower the priority for the SRV records for this inactive VCS.
Please remember to rate helpful responses and identify helpful or correct answers.
