VCS CUCM integration unknown CLI on CUCM endpoints
ciscophonewala
Hello Techies,
I have done integration of VCS (7.2) and CUCM (version 9.1). Call from VCS to CUCM are working but the incoming CLI displayed on CUCM endpoint is "Unknown". Missed call shows the called party's System Name (which is AlphaNumeric).
I found following link which mentions that CUCM has limitation of displaying Alphanumeric CLI for incoming calls.
https://supportforums.cisco.com/message/3776531
Since, the above answer was about 9 months ago, Has anything changed in CUCM 9.1 to display Alphanumeric CLI?
Thnx
wala
ahmashar
Level 4
Level 4
Hi Wala,
9.1 is still the latest version for CUCM.
regards, Ahmad
Patrick Pettit
Hi Wala. What device are you using that is displaying unknown? This ip phone or another device?
VR
Patrick
Sent from Cisco Technical Support Android App
