VCS-E Private Key
jamie.mai
I created a CSR from the first VCS server and received my SAN cert for both VCS-E servers. I installed on first server, all good. Now I want to install on second server and asks for private key. I tried copy/pasting the PEM from the first server at the top of the Server Certificate page next to the cert into a file but says invalid private key when I try to install, Where do I get the private key? I tried searching this site but getting an Ajax error. Thanks!
Alok Jaiswal
Level 4
Level 4
SSH on the server from where you have generated the CSR and already uploaded the certificate.
You need to login as root  and then go to the folder root/tandberg/persistent/certs.
Inside this you will see the priv-key.pem file, you can use the cat command to read the content and copy it in a text file and save it as .pem file.
After this try to upload the certificate on the second server using this priv-key.
You can also use winscp to login using root to VCS if you are not comfortable with CLI mode. Path location will be same.
Alok
10 Replies 10
Patrick Sparkman
If you generate the CSR on VCS, you don't get to see the private key, or do anything with it, you just get the CSR and then you need to upload it after it has been signed.  The private key is stored securely on the VCS and cannot be viewed or downloaded.
If you generate the CSR and key with something like openssl, then you can upload both of them.
Alok Jaiswal
Level 4
Level 4
Alok
Thanks for all the responses guys, I was able to follow Alok's suggestion to use root to copy the key from the first server and was able to use it to upload with the cert on the second server. For the record it is not a clustered environment, I have one server for remote Jabber and one for Jabber guest. Thanks again!
login in to exp e publisher as root
Copy the private key from publisher:
~ # cd /tandberg/persistent/certs
~/persistent/certs # ls -a
~/persistent/certs # cat privkey.pem
Copy the private key, save it in editor as private.pem  -> import it into the secondary server. As the server certificate, you can select the certificate generated for the publisher. Upload -> restart the subscriber and check exp c zone for connection status. It should show green in appr. 3 min again.
hi,
thank you for your reply, i find the file, but can not copy from command prompt, as i am login with VM console
please suggest
thank you
Aliasgar Jhabuwala
Elias Sevilla Duarte
I wonder if you generated CSR for a clustered system, meaning that both VCS-E described above are in a cluster.
If that is the case, here is what the guide says about clustered systems:
Server Certificates and Clustered Systems
When a CSR is generated, a single request and private key combination is generated for that peer only. If you have a cluster of VCSs, you must generate a separate signing request on each peer. Those requests must then be sent to the certificate authority and the returned server certificates uploaded to each relevant peer. You must ensure that the correct server certificate is uploaded to the appropriate peer, otherwise the stored private key on each peer will not correspond to the uploaded certificate.
The above indicates that not even extracting the private key from the first VCS-E will make the certificate upload to work, as the private key will mismatch.
Clonclusion: You need a CSR to be generated in each VCS-E, and then upload separate certificaes to each one peer.
Page 8 on the below guide:
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/config_guide/X8-9/Cisco-VCS-Certificate-Creation-and-Use-Deployment-Guide-X8-9.pdf
I hope this helps.
Hi Elias,
I can confirm you that's wrong. What document says is the best practice only.  But while generating a certificate for e.g. even in a clustered system you get two options,
1) cluster FQDN and this peer only
2) cluster FQDN and all peers.
if you choose second option, then you can just get one certificate signed and that will contain the other peer under SAN entry.
And then you can get the priv-key file from the location mentioned in this thread and upload it on second node with same signed certificate.
Alok
Hi Alok,
I may be wrong, but if the Cisco guide says that this is a "must" then I don't argue, but you could be right.
My statement refers to clustered systems.
Cisco documents when it comes to certificates and UC products tend to be a little how do we say not always correct.
. I have been myself told by TAC that you can not copy a private key off one expressway to another yet have seen it working and been told by another Cisco engineer they did it to a production system.
. ca.pem.default crl-update.conf policy-services.crl privkey.pem.default server.pem
.. client-ca.crl .crl-update.conf.bak policy-services.crl.default sch_server_cert.pem server.pem.default
ca.pem client-ca.crl.default generated_csr privkey.pem sch_server_cert.pem.default server-ssh.pem
----BEGIN PRIVATE KEY-----
MIIJPwIBADANBgkqhkiG9w0BAQEFAASCCSkwggklAgEAAoICAQCjxNnDTSDeiKSU
o1JONOB9iXux/+2fG1wCDmj4vo1daHcYFCbQA+ZYV1mMOyvsNi/SwZem1H1NloTL
DjsmkpkDp7I9Gi2VOTmXvfyMepYoeaF20E13VW9I2vhhbWkV5VEZs2OEm2/e6Qq0
RjDiXKU1gSlI3ATZDTngIIAAO608PHykUEAwxKk+05Jj5uyif6pPAKbZnE5SNCCIK/zn
2ZV/WQVo3gb6sL3mBw0o3ibXeDmU23qb3AshvgsaQxaVBP0wt5FSX57kEUL3uKk
GXbHrV+slw02PgI3nj76MlHZrOTJN20OqiEAfQnTpG/+dFUI9hdh2nhkamxxkXQ==
-----END PRIVATE KEY-----
