VCS-E SRV Records for Multiple Regions
Andrew Vasel
I have a production region with a cluster of 2 expressways, and a test region with a single expressway.
Since I set up the test region first, I have SRV records in place for the test expressway:
Here is an example of 1...
_sip._tcp.example.com. 86400 IN SRV 10 10 5060 testvcsx.example.com
How can I set up SRV records for the production cluster using the same domain (example.com) but still be able to separate my production and test registrations, call traffic, etc?
ahmashar
Level 4
Level 4
Hi Andrew,
you need somehow to distinguish between prod and test platform.
I would suggest to leave prod domain to be as (referring to your example) example.com and test to be test.example.com
The DNS SRV response is a set of records in the format of:
_ service. _ protocol.. TTL Class SRV Priority Weight Port Target
Where Target is an A-record defining the destination and for a cluster it can be the cluster FQDN.
so if you have a cluster as prod and a standalone as test, you can implement like this:
_sip._tcp.example.com. 86400 IN SRV 10 10 5060 vcscluster.example.com
and you test domain to be resolved by:
_sip._tcp.test.example.com. 86400 IN SRV 10 10 5060 testvcsx.test.example.com
regards, Ahmad
ahmashar
Level 4
Level 4
Hi Andrew,
regards, Ahmad
Alok Jaiswal
Hi Andrew,
I don't think you can separate this way the prodcution and test cluster. because when the outside clients sends the request for srv records for a particular domain you will see the reply coming with all the expressway ip's (if set with same domain).
so as mentioned by Ahmad please use separate domain to create srv records.
Rgds
Alok
Martin Koch
I would say it depends on what you want to do.
Either you could do a additional domain for testing, especially if you need to share resources
that might be the better way (like you only have one vcs-e and you need a traversal zone and
be reachable from the outside).
In addition some search rule magic can be handy (like test.whatever@maindomain.com gets whatever@maindomain.com on the test system).
Also a complete seperated setup with a split DNS which is only valid on your test systems can be an option.
Others have a complete mirrored system with a mockup network with the same addresses, ...
It all depends on what you want to archive what would be the best way for such a setup
On one hand you want a separation on the other a clear split, not all is possible at the same time :-)
What I would do is to have the main domain properly set up.
Check out the cluster admin, basic vcs-c/e deployment guide and the admin guide,
they tell you what you should set up.
http://www.cisco.com/en/US/products/ps11337/tsd_products_support_series_home.html
CAVE! The info from Ahmed might be misleading. A SRV record by RFC is not allowed to point
to an IP address, it has to be an A record!
Also if you have a cluster you do not want to point it to ne
vcscluster.example.com record, you want to add two with the same weight/priority
to  vcs1.example.com/vcs2.example.com
As you mentioned _sip/5060, make sure that you also have _sips/5061 as you should
use encryption anyhow, as well for legacy systems have h323 in place as well.
Again, check the guides, its nicely listed there what has to be set up. If you have questions after reading
these documents, feel free to ask again.
Please rate the answers using the stars below and set the thread to answered if it is!
Andrew Vasel
Thanks a lot for the replies, guys. I am going to use test.example.com for my test region SRV records and see how that goes.
BTW, I have read all the documentation for the VCS, and it is not always as clear or expanded as it could be or account for all scenarios.
