VCS expressway firewall rules
nuinoahmed
I just need your confirmation about the following setup.
VCSC ------  FW ------- Internet
                    VCSE
We are using Dual Nic option key with NAT.
VCS expressway wil be connected with only 1 LAN interface to FW.  It will have a private ip address.  Firewall will be Natting the VCSE private ip address to a public ip address.
When updating the FW rules as per following link:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Basic_Configuration_Cisco_VCS_Control_with_Cisco_VCS_Expressway_Deployment_Guide_X7-1.pdf
Appendix 3 - Page 55-58
What VCS expressway  ip address do you need to use for FW rules?  private or public one?
Thanks in advance.
Ahmed
Martin Koch
Hi Ahmed!
If you use the VCS-E with the dual interface option for NAT with only one interface all communication,
from the internet and from your internal network have to go to the _public_ ip address, not the private
one. So its not only on the firewall, but also the destination for the traversal zone on the VCS-C.
Regards your firewall it will depend on what your firewall needs to have configured.
Some firewalls (or at least the admins/users) seem to have issues getting the vcs-e reached from intenal on the
external ip. If this is an issue you would need to use the secondary interface of the vcs and define an additional
dmz.
Please remember to rate helpful responses and identify helpful or correct answers.
Martin Koch
Hi Ahmed!
dmz.
Thanks Martin,
We suggested to customer the option to use the second interface but he prefer to use only one.  So FW admin will have to make it working with public ip address :-)
So I will ask for FW rules using the public ip address.
Best regards,
Ahmed
Hi Ahmed!
Thank you for your feedback! (+5 for you).
Yes, and I would not be surprised if it will end up of the customer using a second dmz and the second interface ;-)
VCS-C - FW - (1) VCS-E (2) - FW - Internet
