VCS Expressway Starter Pack Admin Password
dtom
We are running VCS Expressway Starter Pack ver x.7.1.  Everyting was working fine until we had to logon as the Admin user.  The Admin user and password are still set as the default - admin/TANDBERG.  When we try to login via the web inerface (Administrator login) we get the message - Login failed invalid authorization and credentials.  When we login via telnet session using admin/TANDBERG we are able to login.
What do we need to do to be able to login via web interface (which had worked previously)?
6 Replies 6
awinter2
Level 7
Level 7
dtom,
you are positive you are accessing the 'Admin' login page, not 'User' login?
Have you by any chance configured any per-account or session limits on the 'System' page of the VCS web ui?
If you log in as 'root' over SSH and run the command 'tail -n20 /var/log/messages' immidiately after attempting to log in as 'admin' via web, do you see anything interesting which relates to the failed login?
Tomonori Taniguchi
As Andreas mention, VCS-E Starter Pack has two login pages.
One for system administration, https:///login.
Other for FindMe configuration per user account, https:///user/login.
Unless created “admin” FindMe account, can’t login with admin account by using https:///user/login.
Also please note that default administrator account on VCS-E SP is “admin” not “Admin” (case sensitive).
I am using he following page to login via web:
https:///login
username - admin
password - TANDBERG
When I run the following command on the console (via ssh) as root:
I get the following:
Nov 16 07:33:06 VCS_EXPWY_SP sshd[12363]: Event="sshd" Module="openssh" Level="INFO"  Detail="Postponed keyboard-interactive for admin from 206.78.212.250 port 40953 ssh2" UTCTime="2012-11-16 15:33:06"
Nov 16 07:33:16 VCS_EXPWY_SP sshd[12363]: Event="sshd" Module="openssh" Level="INFO"  Detail="Postponed keyboard-interactive/pam for admin from 206.78.212.250 port 40953 ssh2" UTCTime="2012-11-16 15:33:16"
Nov 16 07:33:16 VCS_EXPWY_SP sshd[12362]: Event="sshd" Module="openssh" Level="INFO"  Detail="Accepted keyboard-interactive/pam for admin from 206.78.212.250 port 40953 ssh2" UTCTime="2012-11-16 15:33:16"
Nov 16 07:33:16 VCS_EXPWY_SP sshd[12362]: Event="pam" Module="pam_unix(sshd:session)" Level="INFO"  Detail="session opened for user admin by (uid=0)" UTCTime="2012-11-16 15:33:16"
Nov 16 07:33:16 VCS_EXPWY_SP sshd[12362]: Event="sshd" Module="openssh" Level="INFO"  Detail="User child is on pid 12458" UTCTime="2012-11-16 15:33:16"
Nov 16 07:33:16 VCS_EXPWY_SP sshd[12458]: Event="sshd" Module="openssh" Level="INFO"  Detail="Attempt to write login records by non-root user (aborting)" UTCTime="2012-11-16 15:33:16"
Nov 16 07:33:16 VCS_EXPWY_SP sshd[12459]: error: open /dev/tty failed - could not set controlling tty: Permission denied
Nov 16 07:33:16 VCS_EXPWY_SP tshell: Event="Admin Session Start" Detail="CLI session 206.78.212.250 40953 206.78.212.201 22" user="admin" Level="1" UTCTime="2012-11-16 15:33:16"
Nov 16 07:36:17 VCS_EXPWY_SP web: User="admin" Event="Admin Session Login Failure" Src-ip="206.78.212.250" Src-port="10986" UTCTime="2012-11-16 15:36:17"
Nov 16 07:44:32 VCS_EXPWY_SP sshd[12458]: Event="sshd" Module="openssh" Level="INFO"  Detail="Connection closed by 206.78.212.250" UTCTime="2012-11-16 15:44:32"
Nov 16 07:44:32 VCS_EXPWY_SP sshd[12458]: Event="sshd" Module="openssh" Level="INFO"  Detail="Transferred: sent 10224, received 6992 bytes" UTCTime="2012-11-16 15:44:32"
Nov 16 07:44:32 VCS_EXPWY_SP sshd[12458]: Event="sshd" Module="openssh" Level="INFO"  Detail="Closing connection to 206.78.212.250 port 40953" UTCTime="2012-11-16 15:44:32"
Nov 16 07:44:32 VCS_EXPWY_SP sshd[12362]: Event="pam" Module="pam_unix(sshd:session)" Level="INFO"  Detail="session closed for user admin" UTCTime="2012-11-16 15:44:32"
Nov 16 07:45:27 VCS_EXPWY_SP sshd[14226]: Event="sshd" Module="openssh" Level="INFO"  Detail="Set /proc/self/oom_score_adj to 0" UTCTime="2012-11-16 15:45:27"
Nov 16 07:45:27 VCS_EXPWY_SP sshd[14226]: Event="sshd" Module="openssh" Level="INFO"  Detail="Connection from 206.78.212.250 port 36609" UTCTime="2012-11-16 15:45:27"
Nov 16 07:45:39 VCS_EXPWY_SP sshd[14227]: Event="sshd" Module="openssh" Level="INFO"  Detail="Postponed keyboard-interactive for root from 206.78.212.250 port 36609 ssh2" UTCTime="2012-11-16 15:45:39"
Nov 16 07:45:42 VCS_EXPWY_SP sshd[14227]: Event="sshd" Module="openssh" Level="INFO"  Detail="Postponed keyboard-interactive/pam for root from 206.78.212.250 port 36609 ssh2" UTCTime="2012-11-16 15:45:42"
Nov 16 07:45:42 VCS_EXPWY_SP sshd[14226]: Event="sshd" Module="openssh" Level="INFO"  Detail="Accepted keyboard-interactive/pam for root from 206.78.212.250 port 36609 ssh2" UTCTime="2012-11-16 15:45:42"
Nov 16 07:45:42 VCS_EXPWY_SP sshd[14226]: Event="pam" Module="pam_unix(sshd:session)" Level="INFO"  Detail="session opened for user root by (uid=0)" UTCTime="2012-11-16 15:45:42"
Nov 16 07:46:35 VCS_EXPWY_SP web: User="admin" Event="Admin Session Login Failure" Src-ip="206.78.212.250" Src-port="51835" UTCTime="2012-11-16 15:46:35"
I can also ssh with the user/password - admin/TANDBERG
Hi dtom,
Which browser do you use? Try Internet explorer9 i think should be work and change default credentials as soon as possible.
B
I am currently using IE9.  I just tried Firefox and it worked fine.  Any thoughts as to why IE9 is not working?
Try reset IE9 settings, delete cookies, store passwords etc...
