02-01-2019 12:38 PM - edited 03-18-2019 02:37 PM
Hello team,
On the release note of Expressway X.10, it says: Calls to Webex via Expressway need to enable TLSv1.0.
Does Webex CMR Cloud support TLS 1.2 now?
We have the requirement to disable TLS 1.0 and TLS 1.1, however 70% of the traffic on our expressway is Webex.
I'm wondering if we upgrade to X.12.5, and disable TLS 1.0 and 1.1, Webex inbound calls would fail.
Aubin
Solved! Go to Solution.
02-01-2019 11:11 PM
Hi There,
The Webex cloud support TLS 1.2 .
Please refer below documents;
Beginning Aug. 3, 2018, Cisco Webex will only support Transport Layer Security (TLS) 1.2. For more info, see: https://collaborationhelp.cisco.com/article/cc09hk
Shalid
Please remember to rate helpful responses and identify helpful or correct answers.
02-01-2019 11:11 PM
Hi There,
Shalid
