03-04-2014 03:55 AM - edited 03-18-2019 02:41 AM
There seems to be a character limit of 128 chars in this field, is there a reason for this and will it be increased in future versions?
Solved! Go to Solution.
03-04-2014 10:47 AM
Its always handy to post the softwre version you are using.
If its critical for you please consider a feature request, but
I would not see it as critical as you could also use openssl to generate the CSR yourself.
So you are not bound to the webinterface!
Please remember to rate helpful responses and identify helpful or correct answers.
03-04-2014 10:47 AM
03-04-2014 04:09 PM
Lastest and greatest, thanks for pointing that out, I'd forgotten about using openssl.
Cheers
