VCS Generate CSR - Additional alternative names character limit
Darren Goulden
There seems to be a character limit of 128 chars in this field, is there a reason for this and will it be increased in future versions?
Martin Koch
Its always handy to post the softwre version you are using.
If its critical for you please consider a feature request, but
I would not see it as critical as you could also use openssl to generate the CSR yourself.
So you are not bound to the webinterface!
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/X8-1/Cisco-VCS-Certificate-Creation-and-Use-Deployment-Guide-X8-1.pdf
Please remember to rate helpful responses and identify helpful or correct answers.
Martin Koch
Lastest and greatest, thanks for pointing that out, I'd forgotten about using openssl.
Cheers
