VCS Ldap connection for admin Login failed
rasimyigit
Hi All,
I have a a problem with the LDAP connection of the VCS control.
As far as I have configured everything in the lab with the port of 389. That works fine.
In another case at my customer, I need to use the port 3268. The LDAP connection is green but I can not login with the defined user-de.
I put the setting on both (local/remote) like my Lab but it doesnt work.
Any Ideas?
The VCS Version is X7.2.1
awinter2
Level 7
Level 7
when you connect to LDAP over port 3268 rather than 389, this means you are searching in the global catalog, which in turn means that you might have to adjust the Base DN for groups and accounts compared to your lab setup where you are connecting to port 389, in order to locate the accounts and groups you are attempting to match against.
rasimyigit
Thx got your message. With the 3268 it doesn't exist a problem or a bug ? I checked all guides and I saw only 389 and 636 port for ldap. The accounts and groups should be right and I tested with all Combination but it will not works
