VCS Login Failure
have a physical VCS running 7.2.2 software as a Controller.
Somehow the configuration got changed so that it is trying to authenticate Remote logins via LDAP that has not been configured.
Therefore, all web access seems to be dead, but I can connect through the console cable to make changes.
But I can not find in the xconfinguration parameters where I tell the system to use the local database for authentication for both admin and user.
any help is appreciated
Alok Jaiswal
Hi Richard,
Even though the LDAP fails your local authenticaton works if under the configuration you set to remote login "both".
Coming to your problem, If you have root access then you can login through the root and then run the command "tsh" which takes you to t-shell basically to admin login.
run the command "xcommand DefaultValuesSet level: 2" this will wipe of your LDAP authentication configuration.
now you should be able to login as local admin through web page. if you don't have admin password then login through root again and run the command "passwd admin" and reset the password for admin.
Rgds
Alok
Wayne DeNardi
According to the documentation, even if the authentication source is set to something else, you should still be able to log in via the "admin" account.
You could try taking note of what the LDAP Server Address is in the config, then set it back to blank to make the LDAP fail and revert to local authentication with:
   xConfiguration Login Remote LDAP Server Address: ""
Failing that, you could try resetting the authentication source (step 4 below) and/or the root or admin password via the serial connection:
1. Connect a PC to the VCS using the serial cable
2. Restart the VCS.
3. Log in from the PC with the username pwrec
4. If the administrator account authentication source is set to Remote, you are given the option to change the setting to Both; this will allow local administrator accounts to access the system.
5. Select the account (root or admin) whose password you want to change.
6. You will be prompted for a new password.
The pwrec account is only active for one minute following a restart.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Alok Jaiswal
Hi Richard,
Rgds
Alok
That did work, but caused some additional problems in that I had to re add all of the configuration information.
there has got to be a more gentle way of fixing that.
but it is working again.
Hi Richard,
It should not have done that. it is supposed to wipe of LDAP configuratin only.  if you run value set level as "3" it will remove all the configuration along with ip-address, but level "2" should be ok.
value set level 2 should reset below things.
Configuration items reset by DefaultValuesSet level 2
The following table lists the configuration items that are reset by xCommand DefaultValuesSet
Level: 2 and their reset values.
Configuration item Reset value
Alternates Cluster Name
Authentication ADS ADDomain
Authentication ADS Clockskew 300
Authentication ADS DC Address
Authentication ADS Encryption TLS
Authentication ADS KDC Address
Authentication ADS KDC Port 88
Authentication ADS Mode Off
Authentication ADS SecureChannel Auto
Authentication ADS SPNEGO Enabled
Authentication ADS Workgroup
Login Administrator Groups Group [1..30] Access ReadWrite
Login Administrator Groups Group [1..30] Name
Login Administrator Source Local
Login Remote LDAP BaseDN Accounts
Login Remote LDAP BaseDN Groups
Login Remote LDAP DirectoryType ActiveDirectory
Login Remote LDAP Encryption Off
Login Remote LDAP SASL DIGEST-MD5
Login Remote LDAP Server Port 389
Login Remote LDAP VCS BindDN
Login Remote LDAP VCS BindPassword
Login Remote LDAP VCS BindUsername
Login Remote Protocol LDAP
Login User Groups Group [1..15] Access ReadWrite
Login User Groups Group [1..15] Name
Login User Source Local
Rgds
Alok
