VCS-MCU
bobby.jacob
Our client has VCSC,MCU with Profile, C90, EX, MXP's registered across the different sites, now they are going to implement security on their network.
What are the consideration to be taken on the Protocols and ports. All the endpoints and MCU are registered with SIP and H323.
Can i have a document on it!
tnx
kntieche
Hi Bobby,
maybe you should be more detailed about how you want to implement that security. You want to authenticate device/user with an LDAP server or using local databse on the VCS? If that the case, you might start looking at the guide below
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Authenticating_Devices_Deployment_Guide_X7-2.pdf
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Authenticating_Accounts_Using_LDAP_Deployment_Guide_X7-2.pdf
Cheers
Karim
Hi Karim,
We dont require AD integration, the VCS,MCU and endpoints are in separate network, the ports 1719 and 1720 are opened already for h323 and 5060, 5061 are opened for SIP.
What are the other ports to be opened?
tnx
Hey Bobby,
For port information refer to the VCS Firewall Deployment Guide.
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_IP_Port_Usage_for_Firewall_Traversal_Deployment_Guide_X7-2.pdf
and depending on your MCU deployment.
Ports used by Cisco acquired TANDBERG/Codian Conferencing Products, and Cisco TelePresence Serial Gateway Series and ConferenceMe
http://www.cisco.com/en/US/docs/telepresence/infrastructure/articles/conferencing_products_conferenceme_ports_used_kb_3.shtml
Adam
