VCS network mapping
Justin Pascal
Beginner
Beginner
Im trying to install VCS from Vsphere client.
I'm following this guide:
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/install_guide/Cisco-VCS-Virtual-Machine-Install-Guide-X8-6.pdf
Which shows a Network mapping option.
Im using Cisco BE6K, ESXi server version:
esxcli system version get
   Product: VMware ESXi
   Version: 5.5.0
   Build: Releasebuild-2068190
   Update: 2
I don't see network mapping option, to pre-configure image I need to use wizard, how can I display this option?
Oleksandr Yurchenko
Rising star
Rising star
Hi Justin
I think you look  " Deploying ova to host using vCenter".
But BE6K don't include vCenter.
You chapter below " Deploying ova to host using vSphere client"
br Oleksandr
Patrick Sparkman
Even if you're unable to enter the network properties using the GUI, you can still configure them using the VM guest console with the install wizard, refer to the "Configuring the VM guest (vSphere clients)" section starting on pg 13.
