VCS reports software issue after IP change
msloan
I changed the IP from the front panel of our lab VCS and now when I try to login I get the following messages:
VCS login: admin
Password:
Last login: Wed Jun 12 09:08:55 EDT 2013 on ttyS0
2 alarms:
  * error     Application failed - An unexpected software error was detected in hwstatus.py: Received a URLError exception while trying to update the hw Status information
  * warning   Date and time not validated - The system is unable to obtain the correct time and date from an NTP server
Run install wizard [n]: n
[10451] Failed t
The front panel is reporting software errors:
MISSING LAN:eth2
MISSING LAN:eth3
I checked /etc/network/interfaces and there are no entries for eth2/3.
Does someone know how to troubleshoot this?  I checked out the python script it mentions and have run it verbose myself from the CLI and it hangs after a bit and does nothing.  I have not been able to find similar issues on any forum or documentation.  Any help is appreciated.
Paulo Souza
I took the same case two days ago, I opened a TAC support and it was necessary to replace the VCS appliance via RMA.
Paulo Souza
Paulo Souza Was my response helpful? Please rate useful replies and remember to mark any solved questions as "answered".
Paulo Souza
Paulo Souza
Thanks, Paulo.  I don't know if we're covered on this one, I'll need to check.  I appreciate the quick reply.
Marty
