VCSE 7.1 to 7.2 Software error
Lonemaker
Hi there,
i get the following message after upgrading VCSE 7.1 to 7.2
An unexpected software error was detected in httpserver.py: Handler="GetXmlHandler"
Incident Detail:
Traceback (most recent call last):
File "/share/python/site-packages/ni/xmlapi/utils.py", line 124, in wrapper
return func(self)
File "/share/python/site-packages/ni/xmlapi/utils.py", line 99, in wrapper
return func(self)
File "/share/python/site-packages/ni/xmlapi/handlers/getxml.py", line 128, in GET
self.insert_plugin_elements(plugin, parent_element)
File "/share/python/site-packages/ni/xmlapi/handlers/getxml.py", line 183, in insert_plugin_elements
elements = plugin.get()
File "/share/python/site-packages/ni/xmlapi/simpleadapter.py", line 169, in get
self._get_walk_recursive(self.xml_structure, record, builder)
File "/share/python/site-packages/ni/xmlapi/simpleadapter.py", line 137, in _get_walk_recursive
self._get_walk_recursive(value, record, builder)
File "/share/python/site-packages/ni/xmlapi/simpleadapter.py", line 145, in _get_walk_recursive
builder.data(str(field_value))
UnicodeEncodeError: 'ascii' codec can't encode character u'\xdc' in position 5: ordinal not in range(128)
And in TMS the connection to VCSE (with Version 7.2) remains with Ticket
#139 - The system is busy - The system is shutting down, or starting
Anybody know how to fix this?
CCNP R&S
Any (reverse/transparent) proxy in between tms and vcs?
Do you have any external scripts accessing the API?
Do you have any "strange" = non asci characters in any of your configuraton fields (like local charsets, UTF-8, chinese, ....), if so I would try to remove them and replace it with 7-bit ascii. (especially if you have the letter "Ü" somewhere (any where in the config, systen name, search rule names, descriptions, .... Please remove everything which is not [a-z][A-Z])
A xconfig and xstatus via the admin CLI  (TSH) might help you to find these.
14 Replies 14
Tomonori Taniguchi
Do you continue to see same alarm/error message even after VCS manual restart once again?
Restart and Reboot, no difference in alarm/error.
CCNP R&S
Hi Lone,
It would be good if you can open a TAC case for this!!this error requires in depth analysis of logs and probably will require you to collect system snapshot as well
Alok
Ok. i will do this.
CCNP R&S
rizpatel
Was this upgrade sucessfull ??
It looks like a image error. I would recommed you to download a new image and upgrade again and also try using English verison.
Rizwan
i redownloaded the version s42700x7_2_0.tar.gz but there is no difference. I dont think this would be an image error, because the version is running "stable"...except of the error above :-)
CCNP R&S
The error was the non ascii. I used an "Ü" and the VCSE saved it as "\xdc" in config. I removed it and rerun the upgrade, everthing is fine. :-)
CCNP R&S
CCNP R&S
Where in the VCS config were you attempting to use this "Ü" character?
- Andreas
Hi Andreas,
under System->SNMP->Location
CCNP R&S
CCNP R&S
And when exactly did this error message appear? What did you do to trigger it so to speak?
Andreas
Thanks for the clarification, I have raised a defect for the VCS so that this can be addressed.
-Andreas
Dafür vielen Dank :-)
Lonemaker: Thx for the feedback, rating and set the thread to answered. +5 for you as well!
