05-29-2007 09:55 AM - edited 03-17-2019 09:02 PM
We have 9 VG248 in our VOIP infrastructure. VG248 is now End of Support from Cisco, what is best desigb to have 9x48 ports with minimum physical hardware? is there any NM-HDA available with high port density??? what is best solution???
05-29-2007 11:13 AM
Hi Divyesh,
I have not seen an EOS/EOL notice for the VG248 (in fact I am just about to install 7 new ones as part of our transition). Have a look at this doc (I don't see the VG248)
Please let me know where you received this information if possible.
Rob
05-29-2007 11:22 AM
here is link i am looking and it says VG248s are EoSu also my sevice contract notification says they are end of sale
http://www.cisco.com/en/US/customer/products/prod_end_of_life.html
05-29-2007 11:51 AM
In the link above is see the VG200 as EoL but not the VG224 or VG248, that are a different product.
05-29-2007 12:00 PM
Hi Divyesh,
I have to agree with Paolo (5 points for you Paolo :) I have scoured all available areas for info on this., beleive me I don't want to move 300 plus circuits onto a piece of equipment that is EOL/EOS. I only have ever seen the VG200 as EOL/EOS, which as Paolo correctly indicated, is a different "kettle of fish" altogether.
Have a look;
http://www.cisco.com/en/US/customer/products/hw/gatecont/ps2250/prod_eol_notice09186a008032d4d4.html
Hope this helps!
Rob
05-29-2007 02:20 PM
Thank you Rob. I know for sure that your users can feel safe with you at the driving console.
And I will always say "kettle of fish" from now on. It sounds so seamanship!
07-11-2011 05:49 AM
Hi Guys,
I read your above discussion.
I am also having a similar scenario where i have to connect around 400 analog extensions to the system. I would like to know your opinion ? i need around 16 VG224 !!!! Is it a gud idea to install VG224 in such a big number?
I compared the above pricing with installing a new nortal PBX at that location.....the cost is high as compared to 16 gateways!!!!
Can you please share you experience? and suggest?
Nouman
07-13-2011 10:00 AM
Hi Nouman,
If it were me I would be looking at the Cisco 112-FXS Bundle
Cheers!
Rob
07-13-2011 11:05 AM
Very nice it was on the same datasheet ...i did not notice that.....
and what about the configuration!!!! is it the same way as ATA....each phne attached to the FXS will be treated as an endpoint in the CUCM.
I will be taking the same license as for ATA
thanks for the help
rob.huffman wrote:
Hi Nouman,
Cheers!
Rob
