Video call from PSTN
Bishay Bishesh
I use a video IP Phone 8945. Now if someone from PSTN tries to make a video call from his/her 4G mobile handset to my Cisco DID, will I receive the video from other end? Or will the video call work only for internal calls?
Gordon Ross
Level 9
Level 9
Unless you're doing some clever stuff, it'll only come across as audio.
To get video from the mobile phone to your 8945, you'll either:
 - Need to use some kind of IP/SIP connection from the mobile back to your phone.
 - Some video/ISDN gateway on your phone system, and some way to persuade your mobile to make a video call over the PSTN.
GTG
Please rate all helpful posts.
Ok, now, let's say that the customer is an enterprise customer and uses a video endpoint registered on his company's IP PBX (either Cisco or non-cisco). So can he make a video call to my Cisco DID?
And similarly, if I have a call center with video endpoints, can the enterprise end customers make video calls?
By default, the PSTN usually only carries voice. If you want video, you need a data connection somewhere. So either over the Internet using SIP trunks or VCS, or using IP/ISDN gateways to make data calls over ISDN. E.g Cisco
GTG
