Video Conferencing Solution Required
Mansoor Hafeez
Greetings
My customer requires the Video Conferencing between two of his sites those are connected via 512kpbs leased line circuit.
He donot want to involve the Desktop PCs for video conferencing. The solution should be something as if he just pick the phone and dial number to talk to other person.
Is there any solution available from Cisco or any other vendor in this regard?. The solution must be very easy in terms of Operations.
Mansoor Hafeez
5 Replies 5
travis-dennis_2
Level 7
Level 7
If your customer is running Cisco CallManager then here is an option that meets their criteria
http://www.cisco.com/en/US/products/ps6564/index.html
Hope this helps
Please remember to rate all replies
My customer donot have CallManager. Is CallManager really required for such design?
For that design yes. Since you said he wanted it to be as simple as picking up the phone and calling someone to start a video conference.
Take a look here
http://www.cisco.com/en/US/netsol/ns340/ns394/ns158/ns280/netbr09186a00800f9218.html
for some other Cisco solutions but I don't think anything is going to be quite as simple as making a phone call but a few things should be very close.
Hope this helps.
Mansoor, you should be able to achieve the requirement by using any codec enpoint by running H323 and maybe setting up an address book on the device and point to far end. -Adam
