We have registered Cisco 5310 MCU with CUCM 8.6.1, and its added to MRGL, we need to do Video conferencing with Jabber clients, also we have some C40s and ex60s from these devices also we need to do video conferencing,
You can setup AD Hoc conferencing with the MRGL you have created or setup Rendevzous Conferences for users to join as well.
EX60 can run TE6.0 if registered to UCM. If you loaded the cop.sgn file for this, product specific configuration should have a multisite option to use UCM, this will generate the merge button for EX60 on UCM to escalate calls to the MCU like IP Phone or Jabber. MRGL must be added as well. I do believe this may be forth coming in TC6.1 for C-Series on CUCM.
Hope this helps.
VR
Patrick
Learn, share, save
