We are using a Codec Pro running 10.8.2.5. There is an integrated control system sending commands to the system, but we have Cisco Room Navigator panels connected. There is a P60 camera that gets routed to HDMI input 1 and a presentation source that gets routed to HDMI input 3.
When we use the room navigator to tell the codec to 'preview onscreen' and pick 'PC 1' (HDMI input 3), we see the expected video source fill the screen, but we also see the same image in a PIP in the center left. It's not the same as the selfview PIP; we can toggle that on and off separately and it shows up on the other side of the screen.
We can see the presentation PIP showing up on the touchpanel, but if we try tapping it and say 'stop sharing', then all sharing ends. There isn't an option to get rid of just the PIP.
Looking at the API reference, we found 'Video Presentation PIPPosition' but are not sure how/why this is used or how to toggle it off so it won't show up in this fashion.
Any suggestions welcomed!
