Video through CUBE
M02@rt37
How Cube act with video call? Is it possible to transcode video codec as audio codec?
Can I co localized CUBE with Gatekeeper h323? Is there a particular configuration?
Thx
Best regards
IOS no longer supports video transcoding -
https://www.cisco.com/c/en/us/products/collateral/unified-communications/tdm-gateways/bulletin-c25-735945.html
If you use a lower IOS version you can continue to use the feature but TAC and BU won't support it and/or any issues arising from it.
Alternative to this is would be an MCU.
R0g22
What do you mean when you say transcode video as audio ? They are two different things, the codecs are different.
Regarding the GK question, you can have CUBE and gatekeeper co-exist on the same platform. Taken the fact that your CUBE is SIP only and does not do SIP to H.323 interop, there should not be any dial-plan issues.
Start here for GK -
https://www.cisco.com/c/en/us/support/docs/voice/h323/24462-gk-call-routing.html
If you are using ISR-4k, GK is not supported.
Ok, I configure LTI for trancoding audio codec on CUBE. Is it possible to configure the transcoding for video codec by LTI or SCCP mechanism?
Thanks for Gw documentation.
Regards.
Best regards
Thanks a lot.
Best regards
