05-13-2015 08:44 AM - edited 03-18-2019 04:28 AM
we have a videoconference C40 which have no access to the web UI. The software it has installed is: TANDBERG Codec Release TC7.1.4.908e4a9 SW Release Date: 2014-06-12.
We have check that http and https is enabled, but we have no access. However we have telnet and ssh access without problems.
Thank you.
Paco Soler.
05-13-2015 11:47 AM
Hi Paco,
If the C40 is registered in CUCM, you have to enable the web interface from there.
05-14-2015 08:36 AM
Is that necessary to enable web interface? On C20 model it's not needed.
In that case, what version we have to install?
Thank you very much.
05-14-2015 02:29 PM
07-29-2015 12:45 PM
I have this problem also and I'm not registering it with CUCM. Straight out of the box, TC7.1.4 installed. IP is assigned via DHCP but I can not web browse into the codec. I can SSH and the on screen commands work, web browser access doesn't. Third C40 (out of 25) I've had this issue with and haven't been able to find a fix.
07-29-2015 03:04 PM
Mark -
Is HTTP enabled?
xConfiguraiton NetworkServices HTTP Mode: On
If it is enabled and you're still not able to access the codec's web interface, you could try to do a factory reset.
xCommand SystemUnit FactoryReset Confirm: Yes
