04-12-2012 02:22 PM - edited 03-17-2019 11:03 PM
I know that both VCS and TMS can be virtualized.
On the documentation i found that the VCS can be deployed on the same host as other VMs (co-residency) following some sizing guidelines (resourses have to be allocated 1:1, this means that there is no oversubscription).
I also read that the TMS can also be virtualized following the same resources guidelines:
"Cisco TMS can be installed in a virtualized server environment as long as the virtual machine hosting Cisco TMS is allocated sufficient dedicated resources to meet the server and hardware requirements for installation. The resources allocated to the Cisco TMS server instance must be dedicated, and not shared with other server instances. ""
What i dont know if the TMS accepst co-residensy with other applications. What makes me doubt is the following:
"Cisco TMS is resource intensive with specific server requirements, that increase with the activity level and size of the video network being managed. Using a server hosting other applications or websites for hosting Cisco TMS is therefore not supported. "
I dont know if this means that no-corresidensy is supported or that no other application besides TMS should be deployed on the same OS.
What i really want to accomplish with this is to virtualize TMS, VCS expressway and VCS control on the same UCS server. Would it be supported by TAC?
Solved! Go to Solution.
04-12-2012 04:13 PM
Hi it means that the TMS server must be dedicated for the TMS application. No other hosted applications should be present on the same OS.
Hope that helps.
04-12-2012 04:14 PM
As long as the resource and requirement guidelines are followed you will get TAC support.
04-12-2012 04:13 PM
Hope that helps.
04-12-2012 04:14 PM
04-12-2012 07:38 PM
Thanks! These are the answers are just what i need!
04-12-2012 07:58 PM
Do you know if it would be supported to deploy CUCM, CUC, CUPS or some other UC App? (thinking on the side of the UC app).
For example, to host CUCM + VCS + TMS + CUC on the same physical server (assuming that the server has enough resources to host all applications and is one of the Tested Reference Configurations)
04-12-2012 09:42 PM
I keep asking the same question, although I would expect "no" would be the answer with TMS as it runs on Windows, rather than being an "appliance" style application like CUCM or VCS. Cisco can't exactly be held responsible for how Windows acts on a VM.
Still holding out for VCS though
04-13-2012 07:29 AM
hmm.. there are other UC apps that run on Windows (Unity, some of the CC suite) that do support blade coresidency under UC on UCS guidelines.
