01-31-2005 05:27 PM - edited 03-17-2019 08:21 PM
The router doesn´t collect all incoming digits from the bri!
The command "ISDN overlap-receiver T302 is set to 5000"!
Is there any way to set the overlap-receiving timer or the time for collecting the incoming digits to a much higher value?
Thanx Martin
Solved! Go to Solution.
02-01-2005 09:17 PM
Can you send the router config and the debug isdn q931 debugs ?
This sounds like you have a dial peer destination pattern that may be a close enough match for the incoming digits.
02-01-2005 09:17 PM
02-19-2005 09:22 AM
Sorry for the delay! I solved the problem I did an IOS Upgrade to 12.3.11T.
Thank you for your help!
Regards Martin
