Voice Translation rule is too fast!
m.hofer
The router doesn´t collect all incoming digits from the bri!
The command "ISDN overlap-receiver T302 is set to 5000"!
Is there any way to set the overlap-receiving timer or the time for collecting the incoming digits to a much higher value?
Thanx Martin
pacameron
Level 4
Level 4
Can you send the router config and the debug isdn q931 debugs ?
This sounds like you have a dial peer destination pattern that may be a close enough match for the incoming digits.
pacameron
Level 4
Level 4
Sorry for the delay! I solved the problem I did an IOS Upgrade to 12.3.11T.
Thank you for your help!
Regards Martin
