Wall Mount MX800 MX700 MX300 power location
dmattix01
I am having trouble finding information on exactly where the wall outlets for power and data should be located when preparing a room to install a wall mounted MX800.  I see photos of an installed system online and it looks clean, so the power and data must be located behind the unit somehow.  Going through the installation manual, I can't determine where that location should be.
Jonathan Unger
Level 7
Level 7
Please refer to the mx800 wall mount installation guide (page 11).
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/mx-series/installation_guide/mx800-wallmount-installation-sheet.pdf
The cables on the mx800 will be routed through the middle of the bottom section.
