We have a SX20 that won't stop restarting...
Jason Tintes
I have open a TAC ticket, we have tested power supply, we have factory reset and I have done Restore from backup but none of that helped. I have also sent them the logs. Codec still keeps restarting, It will restart connect and stay up for about a minute or two and then start the reboot process again. Is there anything that I can try or is this codec toast?
thanks,
Jason
Patrick McCarthy
My guess is you'll have to RMA it. I would suggest a SW upgrade (or downgrade, you didn't mention what version you are running), but from your description it doesn't sound like it will stay online nearly long enough to do that, so a replacement will likely be required.
Patrick McCarthy
Jason Tintes
Thanks Patrick... the codec is at version 8.2.2 and it has finally been approved to be RMA'd. I was thinking while waiting to hear back from TAC that I could maybe try something but it looks like the codec is toast.
thanks again for you response...
Jason
kikiluv13
My SX20 keeps restarting during software upgrade, please help.
You'll need to open a ticket if you still have a support contract - that will likely need to be replaced.
