05-08-2020 06:54 AM
Hello Team,
I have issue , CUCM register EPs are not able to Call WebEx.
EP>>CUCM>>Exp C >>Exp E >> Web Ex
When we check Exp E search history we see "Request Timeout". In Wireshark we see Exp E ( LAN 2 IP ) re transmission TCP pack packets to WebEx Public IP.
This may be issue port blocked on FW.
I want to know is it necessary we need to open 5061/5060 from internal to external ?
2nd : If we ask FW team to open ports from External to internal than what should be the internal IP is it Public IP of Expressway E or LAN 2 IP of expressway E.
05-11-2020 04:41 AM
05-13-2020 06:50 AM
I pulled the below from our request to FW team, but all this came from the guide https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X12-5/Cisco-Expressway-IP-Port-Usage-for-Firewall-Traversal-Deployment-Guide-X12-5.pdf
Look around page 18, It has some really good diagrams of port usage between exp c, exp e and the firewall to internet.
IP | Port |
Public IP LAN 2 | SIP RTP/UDP - 5060 |
Public IP LAN 2 | SIP TCP/TLS 25000-29999 |
Public IP LAN 2 | SIP TCP 5060 |
Public IP LAN 2 | SIP TLS 5061 |
Public IP LAN 2 | RTP/RTCP UDP 36000 - 59999 |
Public IP LAN 2 | DNS TCP/UDP – 53 |
Private IP LAN 1 | RTP/RTCP UDP 36000 - 59999 |
Private IP LAN 1 | SIP TLS 5061 |
Private IP LAN 1 | SIP TCP 5060 |
Private IP LAN 1 | SIP TCP 25000-29999 |
Private IP LAN 1 | TCP - 7001 |
Private IP LAN 1 | DNS TCP/UDP - 53 |
Private IP LAN 1 | UDP - 123 |
Private IP LAN 1 | TCP 3478 |
Private IP LAN 1 | UDP 3478 |
Private IP LAN 1 | TCP – 22 |
Private IP LAN 1 | HTTPS – 443 |
Private IP LAN 1 | SNMP |
Private IP LAN 1 | TCP/UDP 30000-35999 (syslog) |
Management IP | HTTPS – 443 |
Management IP | TCP - 22 |
rate if helpful!
CHEERS
