Webex Room kit Favorites can't change Protocol after build new contact.
Chris Tsai
When I create a new contact, set up the protocol (ex.Protocol:Auto),
when I want to edit the contact,I changed the protocol: Auto→H.323 and save, the protocol changed from Auto to H.323.
But I changed H.323 back to Auto,Protocol can't change it back.
H.323 to SIP is ok. I have tried CE9.1.4 & CE9.4.0 have this problem.
What should I do?
Wayne DeNardi
I just tested it and this seems to be a bug in the older CE9 software releases (up to and including CE9.5.2).
It has been fixed in the CE9.6.1 software version that is being released this month.
A workaround in the meanwhile if you need to set a contact back to "Auto" is to delete it and recreate it.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne DeNardi
Wayne
Hi Wayne
Thank you very much for your reply,and solved my customer's problem.
