Webex Room Navigator
One of our customer is using Cisco Room Kit and now the touch 10 is not working.
As I see in the CCW touch 10 CS-TOUCH10= is not order able.Can we give Webex Room navigator instead ?current firmware version is CE9.2
7 Replies 7
If you have a valid smartnet, replace it though RMA.
Webex Room Navigator Control Unit  will be the replacement for CS-TOUCH10=
Response Signature
Thanks for your prompt reply
No we do not have a valid smartnet.
Is there any minimum firmware version required to use Room navigator?
you need  CE9.14.3 or later, or Webex Clouds. You need to activate the  smartnet for your device to update to version 9.14.3. If you renew the smartnet you can replace the faulty hardware with a wait period of 30 days.Screenshot 2021-10-06 at 11.40.29 AM.png
Response Signature
tomas_vll
Hello!
See:  https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/webex-room-series/datasheet-c78-744227.html
or https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/software/ce9/software-upgrade-room-navigator.pdf
CE 9.14.3 is the lowest supported f/w. The room kit is supported model, but the f/w is not. so a service contract and a f/w upgrade will be needed.
Hi Below is the firmware version
CE.9.2.1
Will this also require software update to connect room navigator?
You need to bring your CS kit to version CE9.14.3
Response Signature
Thanks this was useful
