Showing results forĀ
Search instead forĀ
Did you mean:Ā
WebRTC chat doesn't work after using API.
Arvin.hsu
The chat function of WebRTC doesn't work. It is just displayed:
"You can't send messages to this conversation"
I have used the API to create "callProfile" and put to "system/profiles" .
The chat funcation still doesn't work.
Can someone help me?
information:CMS version is 2.2.2
I can't tell in the image what action you're using, but you'll want to PUT messageboardenabled to your existing call profile you previously created:
/callProfiles/<call profile id>
Otherwise if you use POST, with just /callProfiles, you'll just create another call profile.
Patrick Sparkman
Within your call profile, did you set the value for messageBoardEnabled to true?
Hi Partrick,
I try again , it is work .
Maybe I type wrong words.
thanks for your help !!
