What is the Coverage Distance by Quad Camera?
WeiKwongOng5555
What is the coverage distance by Quad Camera? How far the camera can zoom in meter?
Thank you.
This will be the best place when sizing VC
https://projectworkplace.cisco.com/en-us/workspaces
Response Signature
Patrick McCarthy
The quad camera has a maximum zoom of 5X. From my experience it can handle up to about 30' away quite well. If the room is larger, the older Speakertrack 60 might be a better choice - it has two cameras that have up to 20X zoom so it can handle a larger room. The downside of the latter is larger cameras that move (which can be distracting), but it works very well.
Hope this helps.
So 30 feet is about 10 m.
Strange nothing can be found in the available documentation or datasheets.
Apart from Speaker track 60 can a P60 camera with speaker tracking also do the trick?
Is there documentation indicating that tracking works at that distance?  If not, is there design guidance documentation to help plan for planning for quad camera vs speakertrack 60 application?
