WiFi settings greyed out when DX80 is registered with CUCM over LAN
Jareeshali K C
Can we turn the WiFi settings to ON in DX80 while it is registered with Cisco Call manager version 11.0 over LAN?
I enabled Wifi under product sepcific Configuration Layout and still the Wifi settings to turn ON or OFF is greyed out.
Is it how DX80 designed to work that when it is connected over LAN, WiFi settings will be disabled on the device?
Jareesh Ali
Wayne DeNardi
When the LAN cable is plugged in to the DX80, it will always use that, and disable the WiFi.  If you want to use WiFi, you will need to disconnect the LAN cable.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne DeNardi
Wayne
Wayne
