WINSCP fails to connect to VCSE
arawnmediagroup
I am not able to connect to VCSE with WinSCP. I have used it before on the VCS. I. Am not sure what changed.
VCSE = 7.1
WinSCP= 4.3.8
File protocol = sftp port 22
Error:
Error skipping start up message: your shell is probably incompatible with the application (bash is recommended)
awinter2
Level 7
Level 7
Chris,
make sure you are logging in as user 'root', not 'admin', I suspect that this is the issue here.
- Andreas
awinter2
Level 7
Level 7
Chris,
- Andreas
Very good catch. Lol. Thank you.
