09-28-2013 06:37 AM - edited 03-18-2019 01:52 AM
Hi all,
I have customer who want to but SX20 quick set but with one customization in its microphone. They want to use wireless microphone instead of the standard wired one. Do you think it is possible? Can you people share some experience or suggestion according to this customization.
thanks.
best regards,
Yedi
Solved! Go to Solution.
09-28-2013 11:40 AM
Hi Yediael,
The SX20 uses standard mini RCA jacks and the omni directional microphone comes with a 7.5m cable.
SX20 is a quickset solution and not a integrator, so i will remcommed you to use microphone shipped along with it.
i have seen people using Revolabs wireless microphone with them but in that case echo issue need to be handled with proper design.
09-28-2013 11:40 AM
Hi Yediael,
09-29-2013 03:52 AM
Hi Amit,
Thanks for the confirmation.
One more question, do you have any experience in cutomizing SX20 quick set with bluetooth microphone device?
thanks.
best regards,
Yedi
