04-29-2018 09:08 AM - edited 03-18-2019 02:04 PM
I have only one CMS 1000 server . but im really confused after reading the deployment guide on virtualized environment perspective.
does single combined server means all roles in one single VM in a physical server or separate roles in different VMs in a physical server (ucs 220 M4) ?
similarly does single split server means edge and core in separate VMs with corresponding roles as mentioned in the guide in a physical host (ucs 220 M4) ? or is it means 2 separate physical host server machine for core and edge server with corresponding roles?
I can see TURN server in both deployment types. TURN should be in the DMZ area right? in that case what is the difference between the two deployment? Both have edge concepts.
please clarify this doubt. I got really confused.
Solved! Go to Solution.
05-07-2018 10:22 AM
05-07-2018 11:21 AM
Have you reviewed any of the documentation for CMS??? the fact that the recorder HAS to be on a separate CMS server/VM/instance is clearly outlined, and that you can ONLY have it co-res for lab/testing purposes.
From single combined deployment guide:
The Recorder should be hosted on a Meeting Server that is remote to the server hosting the Call Bridge, see Figure 19. If the Recorder is hosted on the same server as the Call Bridge (local), then it should only be used for testing purposes
If you have any other server where to deploy the VM for recording that meets the required specs, you can use it.
05-07-2018 12:05 PM
05-08-2018 05:40 AM
