12-06-2012 05:44 AM - edited 03-18-2019 12:15 AM
Is there an approved method from Cisco for disinfecting their remotes. There isn't even anything in the VX Clinical Assistant guide. My infection control staff want to us Virox wipes, or something equivalent.
I'm concerned about it wiping off the numbers/labels.
Darren
Solved! Go to Solution.
03-03-2013 12:08 PM
As long as it is not an abrasive or corrosive wipe or saturated with fluid then you should be OK. If this is something you will need to do regularly then you may want to consider putting the remote in a clear zip lock bag. Or having each user disinfect their hands before use. Otherwise you will not find an 'approved' method since that could open up someone to liability if it didn't work in all situations.
12-24-2012 04:20 AM
Hi Darren.
I will look this up for you and get back to you.
//Marius
03-02-2013 11:59 AM
Hi Marius, and news on this?
03-03-2013 06:12 AM
Are there any kind of plastic covers / bags in which you could put the remote?
03-03-2013 12:08 PM
03-04-2013 05:18 AM
Thanks Russell and Martin. We are already putting the remotes that patients touch into a clear plastic bag, but since Cisco has their telehealth endpoints, I thought they might have another suggestion.
Thanks again.
