ā06-17-2018 10:48 PM - edited ā03-18-2019 02:11 PM
I am trying to get the OBTP feature to work in a lab environment with S4B/TMSXE/CMS. So far conferences are well created in TMS thanks to the TMSXE module but the externally hosted option remains unticked and the video address link is empty. I have added the domain into the TMSXE configuration, the TMS is set with External MCU: Always, Prefered MCU: CMS. I have activated the debug in TMSXE and see:
2018-06-17 22:07:11,729 [23] DEBUG SubscriptionWorkerBase6 - ############ Processing event with appointment: Updated
2018-06-17 22:07:11,729 [15] DEBUG ConferenceNursery - Processing event for meeting: -785630322
2018-06-17 22:07:11,729 [23] DEBUG SubscriptionWorkerBase6 - ############ App type: Single, Start: 6/17/2018 8:30:00 PM, End: 6/17/2018 9:00:00 PM, Subject: Test
2018-06-17 22:07:11,729 [23] DEBUG AppointmentTelePresenceProperties - uccapabilities present : False
2018-06-17 22:07:11,729 [23] DEBUG AppointmentTelePresenceProperties - ucMeetingsetting Present: False
2018-06-17 22:07:11,729 [23] DEBUG AppointmentTelePresenceProperties - OnlineMeetingExternalLink present: False
2018-06-17 22:07:11,729 [23] DEBUG MasterParticipantList - Location field:VC2
2018-06-17 22:07:11,729 [15] DEBUG ConferenceNursery - ConferenceFsm for conference -785630322 does not exist. Creates a new...
2018-06-17 22:07:11,729 [23] DEBUG Cisco.TMSXE.EWS.Adapters.CalendarItemAdapter - Using pidLidAppointmentTimeZoneDefinitionStartDisplay W. Europe Standard Time
2018-06-17 22:07:11,729 [23] INFO SubscriptionWorkerBase6 - PullSubscription event with item PullSubscriptionUpdated Saved/busy
2018-06-17 22:07:11,729 [23] DEBUG EWSItemStorage - Storage: adding item:I218703821 AAMkADBjNTcyYjU2LTZmZjAtNDdjYi05NTQ1LTU0OTRmZTU5YmE2NQBGAAAAAAAWGi/1wEIHQrHi1lWY97fWBwDhfAC0qgeSTIYXVdskGoHnAAAAAAENAADhfAC0qgeSTIYXVdskGoHnAAAJCeGrAAA=
2018-06-17 22:07:11,729 [23] DEBUG SubscriptionWorkerBase6 - Added to storage.
2018-06-17 22:07:11,729 [23] DEBUG ExternalSubscriptionEventDispatcher - NotifyEvent:Notify PullSubscriptionUpdated Saved/busy
Using OutlookSpy, I see that the uccapabilities attribut is present. Any clue?
Maybe @Patrick Sparkman?
BTW: I also try using the WebEx Outlook Add-In with the corresponding Webex configuration in TMS but same result:
ā06-18-2018 02:03 AM
Does it work if you book directly from TMS rather than via Outlook?
ā06-18-2018 04:29 AM
If I book directly from TMS and tick "Externally Hosted" and set the SIP address then everything works fine but the whole idea is to automate this part using the Outlook module.
ā06-18-2018 04:33 AM
ā06-18-2018 08:03 AM
Sorry I shouldn't have mentioned the CMS as I can bring confusion (I tested this option before). The meeting is hosted in the S4B infrastructure and I am just expecting TMSXE to set the externally hosted field with the SIP address in the TMS conference. When I do that action manually after the creation from TMSXE, everything (e.g. OBTP) works like a charm.
ā06-18-2018 01:33 PM
ā06-28-2018 04:50 PM
Are you booking a Skype meeting with Outlook? As that would be required for XE to pick up the Skype meeting details to have it as the externally hosted address.
ā10-06-2018 11:15 PM
Yes booking from Outlook but it seems that none of the attributs from the meeting is picked up by the TMS XE. I tried also using the WebEx PUT from Outlook, verified the presence of the UCCapabilities using Outlook Spy but the TMSXE still report:
2018-10-07 08:06:48,064 [20] DEBUG AppointmentTelePresenceProperties - uccapabilities present : False
2018-10-07 08:06:48,064 [20] DEBUG AppointmentTelePresenceProperties - ucMeetingsetting Present: False
2018-10-07 08:06:48,064 [20] DEBUG AppointmentTelePresenceProperties - OnlineMeetingExternalLink present: False
Any clue in term of how to troubleshoot?
