Bookmark
Subscribe
1485
Presentation codec frame rate
ehab alabed
                   what is the frame rate when I using the PiP as presentation output if I have presenation codec
If using PIP on a CTS 3000 it should be 5FPS.
Using an External monitor your will get 30FPS.
5 Replies 5
mubakhta
Level 4
Level 4
Hi Ehab,
I believe the frame rate is 30 frames/second when using a Presentation codec. Sharing a presentation without Presentation codec will trasmit at 5 frames/second.
Mubashshir Akhtar
Thanks Mubashshir Akhtar
Haydn von Imhof
Level 4
Level 4
Hi Ehad
What system are you using?
For the 500, 1100, 1300 CTS systems, 30FPS is not supported in PIP mode.
So I assume it would be back down to 5FPS
Note The high frame rate codec does not support 30 frames/sec in presentation-in-picture (PIP) mode. An external display is recommended.
The TX series however use a software key and not a presentation codec. So 30FPS in PIP mode might be supported on the TX series.
Thank you,
The system is cts 3000.
if we using the PiP in CTS 3000 with presentation codec the frmae rate is 30fps or its down to 5 fps.
Thank you very much
