VCS model
Louis-Alex
If I have a serial number, can I get the model # of my device, and thus get a physical description of it....
and, if i have to unplug and replug my devices (2 VCS-Control and 1 ExpresseWay) is there a procedure to follow ?....
2 Accepted Solutions
All 3 are old 1st generation TANDBERG hardware appliances, sometimes refereed to as the black pizza box.  The part numbers for them were CTI-VCS-CONTRL-K9 and CTI-VCS-EXPRESS-K9, while the descriptions back then were simply VCS Control and VCS Expressway.  I should also point out that no more software will be released for that particular VCS platform (latest supported release being X8.7.x), and they're coming up on end-of-life in 2019, see eos-eol-notice-c51-731300.
I don't recall there being any specific order. I would power them down cleanly and they should talk to each other properly when powered back up, assuming network connectivity.
8 Replies 8
Joe Vallender
Level 3
Level 3
If you provide the serial number someone may be able to help.
allright :-)
SerialNumber: "52A23314" (VCS-Control-One)
SerialNumber: "52A28113" (VCS-Control-Two)
SerialNumber: "52A27961" (VCS-ExpressWay)
you can visit the site and enter serial number using your CCOID
https://apps.cisco.com/CustAdv/ServiceSales/smcam/requestStatusDispatch.do?methodName=onDashboardAction&tabClick=1
regds,
aman
cool :-)
and, for the reboot ?... :-S
Louis-Alex
I got it !
cti-vcs-contrl-k9
cti-vcs-express-k9
