UCS Director Knowledge Base
Field Notice 70545
Knowledge Base Articles
  Task Name Assigning VM to User Description This task allows for the assignment of a specific VM to a user in UCSD. Prerequisites Add vCenter of version 7 or above to UCSD Category Workflow Components UCSD, VMware vCe...
asheksal by Cisco Employee
  • 825 Views
  • 0 comments
  Task Name Rename VMware VM Description This task allows for the Rename VMware VM from UCSD. Prerequisites Add vCenter of version 7 or above to UCSD Category Workflow Components UCSD, VMware vCenter User Inputs ...
  • 976 Views
  • 0 comments
  Task Name Update VMware vCenter Workflow Description This task provides users a facility to update their vCenter(version 7 and above) from UCSD Prerequisites Add vCenter of version 7 or above to UCSD Category Workflow ...
  • 991 Views
  • 0 comments
Task NameUCSD - Add computer object to groupsDescriptionThis workflow runs as a post provisioning workflow to a standard catalog so that a user uses check boxes to chose whichgroups an AD computer object is added to.  Using a systems management softw...
midupont by Cisco Employee
  • 1796 Views
  • 1 comments
Task NameSimple 3 Tier Stack / Multiple VM(s) / Multiple Catalogs / Multiple VDC(s)DescriptionSimple 3 Tier Stack / Multiple VM(s) / Multiple Catalogs / Multiple VDC(s)PrerequisitesTested on 5.2CategoryWorkflowComponentsvSphere 5.xUser InputsInstruct...
Task NameThis workflow / custom task will e-mail the SR logDescriptionPrerequisitesTested on UCSD 6.0.0.0CategoryWorkflowComponentsvSphere 5.xUser InputsInstructions for Regular Workflow Use:Download the attached .ZIP file below to your computer. *Re...
Top Contributors
