I wanted to know is there a way in CUCM that I can not have the +1 show up on outbound calls made from my CUCM phones. We have SIP going across our internet service and all outbound calls are attaching the +1 and I want to get rid of that and just show the number. For example I dial my cell from my desk phone and my cell caller ID shows the +1 along with the number of my desk phone.
Assuming you're the one adding it, yes, find out what you're using in your config to add it, and remove it. You might be using calling party transformations, or TPs.
java
if this helps, please rate
Learn, share, save
