Exchange 2013 "Hybrid" and Unity Connection Single Inbox
r.stockton
Exchange Admin has advised they are upgrading to Exchange 2013 and will plan on migrating to a Cloud or Hybrid based solution.  Is there good support for this on the Unity Connection side for Single Inbox?
-Robert
Jaime Valencia
Have you reviewed the SIB/UM documentation?? It outlines all the supported message store options we currently support.
java
if this helps, please rate
