11.5 Unity Connection SSO Per node (One metadata file per node) option
rwalker0111
I am trying to set up Unity Connection SSO.  I have a Pub/Sub HA.
I am selecting the per node metadata file option when setting this up.
I can import the metadata file for the pub and get a successful test.
The problem is the sub.  With the single pub meta file the sub fail. I would expect this.
When I upload the sub metadata file it over writes the pub and then the sub is successful on a test.
What is the trick to getting per node meta data files installed on both servers?
Btw I am seeing the same thing when trying per node on CUCM.
Rw
johnmannarino1
Did you ever get this resolved?
