2 PRI's from same Telco on to a 2821
ahrao
I have 2 PRI's from the same Telco.  One PRI is configured, now I have to configure the 2nd PRI (Im fairly new to Voice), can some one let me know how to achieve this, please note that the PRI's have different DID's
Best regards and thanks in advance.
ahrao
jballari
Hi Ahrao, Your question is quite open so before overloading you with info, can you specify what protocol are you using to control the gateway? H.323? MGCP maybe?  Cheers,  Jose
